now that its runs trans issus...
Old Jan 11, 2012 | 06:06 PM
chineseatv's Avatar
Default now that its runs trans issus...
ok well got the thing to run
had it on stands and put it in gear and first worked
2nd worked for about 1/2 turn and locks
3rd sometimes turns a little then locks
rev dont do anything just locks
N is like first drives.. so i assume something is wrong with first?
im sure i need to crack the case any directions to help?
Old Jan 12, 2012 | 05:52 PM
chineseatv's Avatar
might help to let you guys know what it is
Kazuma 110 falcon
any suggestions?
Old Jan 13, 2012 | 05:46 PM
chineseatv's Avatar
i need help guys
aint there some kind of honda manual that works for these things???
Old Jan 15, 2012 | 06:32 PM
chineseatv's Avatar
well i figured out what the issue was.....
the first gear was welded to the shaft.. after spending all day taking it apart and trying to figure out how it worked.. i ended up having to hammer the gear off and then i honed out the inside of the gear and then smoothed the shaft..
put it back together and it works well
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
HondaR24
Jul 23, 2015 11:22 AM
Kdgncop
Jun 17, 2015 09:37 PM
cornermike
May 27, 2015 10:04 PM
Fullblast
May 26, 2015 12:38 AM
