Baja 90 chain troubles
Old Jan 25, 2012 | 04:05 PM
Devlin stutts's Avatar
Default Baja 90 chain troubles
I have Baja 90cc Atv that when riding in the bushes the chain will fall off. I think that this happens because the chain is loose when I get it tightend as much as possible. What can I do?
Old Jan 25, 2012 | 04:35 PM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Welcome to the forum Devlin stutts!
You can either take a link out of the chain or get a new one that isnt so worn..
Old Jan 25, 2012 | 05:18 PM
I have another problem with the chain system as well, if you were to look at the engine sprocket in line with the axel sprocket, they are not in a straight line. the the axel sprocket is about 1/2to 3/4 of an inch to the left of the engine sprocket. I was wondering if that is normal or a bad thing. This is on a baja 90cc
Old Jan 25, 2012 | 05:52 PM
KTM Patrol
Former Chinese POW!
That isnt normal and it isnt good.. its a big part of the problem... try and see if the hub can be turned around on the axle.. or if the sprocket can be bolted to the other side of the hub..
95wolv
Sep 27, 2024 12:00 PM
mrtidy
Feb 3, 2016 05:00 PM
kbazzy
Sep 26, 2015 11:26 AM
Clint Russell
Sep 25, 2015 03:20 PM
Chasso
2) Chassis problems..
Sep 19, 2015 03:06 AM
