50 cc Mini atv start & idle problems
Old Feb 13, 2012 | 03:02 PM
TEW's Avatar
TEW
Default 50 cc Mini atv start & idle problems
First of all, this thing belongs to a friend of mine, I wouldn't waste my money on one. I worked on it for him about a year ago, it had been sitting up a while & carb gummed up. Cleaned it good and it ran o k. Now it got to where it was hard to start till now you can't get it started. The elecric choke wasn't working but that shouldn't keep it from starting, just make it run rich, anyway, got on line trying to find one without any luck. I finally found a new complete carburetor, exact duplicate of the one that's on it pretty cheap so I purchased the new carb & put it on. Problem-It will start then idle up to about 2500 to 3000 rpms then if you hit the throtle it will idle down so slow that it dies, you can feather the throtle to keep it from going dead then it will jump back up to the high rpm. If you just let it sit and run at the high rpm it changes rpm erratically, it throtles up good. Sometimes you have to take the breather off and cover the carb with your hand to get it started. I've already wasted more time on this thing than I think it's worth but I would like to get it running right just so I can give it back to him and tell him not to ever bring it to me again. Any ideas or suggestions are welcome
Old Feb 18, 2012 | 11:45 AM
kairey's Avatar
On mine this sort of thing was narrowed down to the pilot jet been clogged, it was the hole that runs the length of it not the small holes at the top that was gummed up...
On a new carb shouldn't be your problem but your symptoms are the same...
Crap in the tank, change filter, new plug?
KEVIN
Old Feb 18, 2012 | 02:05 PM
TEW's Avatar
TEW
KEVIN
Thanks for the info, I've already cleaned the tank, fresh fuel, new filter & new plug. I'm going to let the boys ride it around the place tommorrow afternoon, maybe if it's ridden some & warmed up good I can adjust a little on the carb & see if it gets any better.
Yamaha_
Utility ATVs
Dec 16, 2022 07:49 PM
02Chevrolet
1) Engine problems..
Jun 23, 2015 12:12 AM
Steven Bandemer
Jun 9, 2015 08:50 PM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
