Rear disc brake dragging
Old Feb 20, 2012 | 11:18 AM
tsethp's Avatar
Default Rear disc brake dragging
Rear disc brake dragging thus causing the brake cylinder to heat up and I have to release the bleeder valve a bit then tighten back to loosen up the brake so the tires will spin. Also the chain comes quite frequently. Any solutions to these problems will be helpful. 110 cc
Old Feb 22, 2012 | 07:32 AM
Jaster94's Avatar
replace the caliper. as for the chain, verify it's lined up and straight. then check the chain tensioners and make sure they're not broken or fouled up somehow. if they don't have lock washers on them, they should. heck, the tensioners may have springs on them. are they ok and intact? good luck.
Old Feb 26, 2012 | 06:51 AM
tsethp's Avatar
ok so the chain tensioners also act as alignment for the rear axle. Well the tacks that hold the tensioner have broke causing alignment issues. Also it looks like that they welded the rear crooked from the factory.
STLyamwar
Jul 25, 2020 04:44 AM
greg74
Sep 10, 2019 03:03 PM
SixSpeed5
8
Aug 2, 2015 05:38 PM
Sandman2.0
Jul 21, 2015 09:03 AM
timster911
Jul 13, 2015 01:57 PM
