Cool Sports 150cc Atv problem
Old Mar 29, 2012 | 07:39 AM
JosephSno19's Avatar
I've adjusted the front adjustment screw to lengthen the drive. It's still lurching a little but it's hardly noticeable compared to what it was. This also fixed the problem I had where it was slipping out of drive. Do I need to lengthen the back nut or shorten it to see if this would help with the lurching?
Old Mar 31, 2012 | 08:54 PM
LynnEdwards's Avatar
Electrical Expert
My adjustment is on top of the gearbox, so we have different gearboxes. But I'm pretty sure they work the same inside. I would figure out where the shift lever was when it was popping into neutral, and where the shift lever is now where it runs pretty good but lurches a bit under load. Then adjust it so it goes a bit further in the same direction between 'popping into neutral' and 'running sort of OK'.
skinnyr6
Aug 25, 2023 02:18 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
honda71
Jul 8, 2015 02:13 AM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
