110cc starting problem
Old Mar 31, 2012 | 06:41 PM
labrador's Avatar
Default 110cc starting problem
relay under seat just clicks when i try to start it, i've tried jumping it at terminals but ther dose not seem to be alot of power ther but the battery is new, any ideas
Old Mar 31, 2012 | 09:14 PM
LynnEdwards's Avatar
Electrical Expert
Your battery is probably bad or discharged. That's the most likely scenario, but it could also be a bad connection, bad starter, frozen engine, and a few other things.
Do you have a meter? You'll most likely need one of these to see where the problem lies. To start troubleshooting:
Measure the battery voltage on DC volts and on the 20 volt scale. Measure this voltage right on the battery terminals while the solenoid is "clicked" in (in other words the battery is being loaded by the starter motor). You should measure above 11.5 volts.
Next try jumping you quad battery to your car or truck battery. Do take extra care to get the polarity right - positive to positive, and negative to negative. Then try to start your quad (using the start button and/or jumping across the starter solenoid). Does your starter motor crank the engine with the jumper cables connected?
Dame0927
Oct 29, 2015 10:13 PM
alix
Jun 28, 2015 03:28 AM
FWhitt
Jun 13, 2015 02:22 PM
kevbowe
Jun 1, 2015 01:17 AM
1000gade
May 27, 2015 12:37 PM
