hammerhead off road
Old Mar 26, 2012 | 12:11 PM
hammerhead25's Avatar
Default hammerhead off road
i have a hammerhead twister which has the honda gy6 engine the starter spins but it want crank the motor over does anyone know what might be going on
Old Mar 26, 2012 | 12:17 PM
Are you sure it's a Honda engine and not a Chinese knock-off. Never heard of Hammerhead but that doesn't mean too much. I've been wrong before.
Old Mar 26, 2012 | 12:28 PM
scootergptx's Avatar
Supersock
Hired Gun!
Welcome to the forums.
First thing I'd check would be to see if the starter solenoid is engaging the flywheel. Hopefully, it's something that easy to diagnose.
Also, I'm moving this over to the Chinese section as this is one of the many clones from that area.
Old Mar 26, 2012 | 01:01 PM
the starter shaft its self spins but does not move in or out it does not have an actuator
Old Mar 26, 2012 | 01:09 PM
Supersock
Hired Gun!
Do you have the starter off the machine? If so, how do the teeth look.
Also, with the spark plug out, can you get the engine to turn over manually?
Old Mar 26, 2012 | 01:15 PM
the teeth look fine. how would i crank the motor over manually?
Old Mar 26, 2012 | 01:16 PM
and your right its a gy6 clone
Old Mar 26, 2012 | 01:38 PM
Supersock
Hired Gun!
Can you roll it while it's in high gear? Just checking to make sure the motor itself isn't locked up.
Old Mar 26, 2012 | 01:49 PM
there is only one gear a hammerhead is a go kart the motor isnt seased up i took side cover off where the magneto is ang i can turn the magneto or the crankshaft so i know its not seased
Old Mar 26, 2012 | 02:05 PM
Supersock
Hired Gun!
Ok, not familiar with it more than I've seen the name in here before.
If the motor is turning, the the flywheel is turning with the motor, I'd go back to the starter itself. You say you hear is spinning, but is it making any other noises? Have you taken it apart yet?
