Info on these types of quads?
Old Apr 11, 2012 | 04:03 PM
Jaster94's Avatar
Originally Posted by ProfitOfDoom
So I guess my next question is,are these types of quads and good or are they pretty much disposable after a season? Or would I be better off getting a used kawasaki,I seen a used 2002 220 bayou needed a fuel needle replaced and they wanted $1000 OBO so I could probably get it for the same as the chinese quad?
Or if you know of another brand or option around that $750 area,let me know. Thanks for the help in advance!
fit the kid to the quad. a needle valve replacement or a good carb cleaning would probably fix that as long as the owner ain't hiding any other problems. off $700 if he can't start it for you. just check the crankcase oil for gasoline contamination if it has stuck open. up to you, your money
Old Apr 11, 2012 | 04:05 PM
Jaster94's Avatar
as far as china quads go, some folks by the little ones, pass them from kid to kid cause they outgrow them fairly quickly. if they break, it's a cheap fix, then sell'em to someone else for a little bit of nothing. for an 11 yr old, the 125-250 size would be fine and last him a while.
Old Apr 19, 2012 | 12:06 PM
Chad Mcconnell's Avatar
Does any one know the model of this quad. It looks to be a Coolster Mountopz-200 but the parts inside do not match up.
http://i483.photobucket.com/albums/r...418_174157.jpg
http://i483.photobucket.com/albums/r...418_174143.jpg
http://i483.photobucket.com/albums/r...418_174135.jpg
Old Apr 19, 2012 | 06:54 PM
Durby's Avatar
should probably start a different thread and you may get better info....
Old Apr 20, 2012 | 02:16 PM
  #15
Jaster94's Avatar
chad,
that looks like a hibird 250cc. not sure the year model, maybe 2009-2010? you'll need to run the VIN to verify. on the front, behind the pushbar, there may be a metal ID tag. look there, if it wasn't taken off, it should be there. if not, check the left hand side of the frame for the VIN and use the decoder.
GregM
Mar 6, 2018 06:53 AM
Captjay
Jul 23, 2015 12:33 PM
xbin87116
Jul 13, 2015 02:10 PM
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
Mojave250A
Jul 11, 2015 10:38 AM
