baha 400 4x4 throttle killing engine?
Old Apr 24, 2012 | 10:28 PM
quadav07's Avatar
Default baha 400 4x4 throttle killing engine?
Bought a baha 400 4x4 last fall from canadian tire. Has about 225 km's on it.
Took It out for the first time tonight. While I was ripping down a trail the engine suddenly lost all power. I took my thumb off the throttle and the quad idoled just fine. As soon as I hit the throttle the engine dies?
Fianlly I messed with the choke a little bit and was able to get moving with the choke fully out. Barely moved but was able to limp back to the garage.
Anyone ever had this problem that can help me?
Old Apr 25, 2012 | 04:05 AM
Jaster94's Avatar
check the compression with a gauge and not your thumb.
verify you're getting an adequate fuel supply.
may need to clean the carb/jets/float assembly.
make sure the fuel tank is vented. either by a vented cap or a hose that's on the fuel cap. either way, we want to rule out the tank experienced a vacuum lock.
replace the fuel filter
make sure the petcock valve is not partially plugged up.
Old Apr 25, 2012 | 08:43 AM
quadav07's Avatar
Thanks I will look into these things. First atv so most of this stuff is new to me.
Old Apr 25, 2012 | 09:16 PM
Jaster94's Avatar
not a problem. education is abundant here. so get ready to learn more and more about quads. it'll help you out on the trail if you happen to stall out or have a malfunction.
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
MNatv89
Jul 7, 2015 11:36 AM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
