quad wont start
Old May 15, 2012 | 02:13 PM
jsmithinstallations's Avatar
Default quad wont start
I have a SUNL 110cc 2006.
It will not start, it cranks but will not start.
also the battery is not holding a charge..
not sure what it could be.
cdi,voltage regulator or stator???
any advice would be great.
Thanks
Old May 15, 2012 | 05:10 PM
mudmike's Avatar
sorry dude u didn't give enough info could be many reasons why it will turn over but not run
does the plug have spark?
have u tried sparying some starting fluid(or similar) in the carb to see to see if it will fire? if so its most likely a fuel problem
not trying to be a wise guy just don't even know which road to look down
Old May 15, 2012 | 08:56 PM
LT80's Avatar
LT80 Expert
Disconnect the battery and charge it. If it doesn't hold a charge, then the battery is bad. If it does hold a charge till connected, then there is a short somewhere.
Is there spark at the spark plug?
Is the plug wet?
Have you cleaned the carb?
Hankey Pankey
26
Oct 18, 2020 03:50 PM
armpump450r
Technical and How-To Articles
Apr 1, 2017 06:11 AM
Scott-Leigh
Jun 6, 2015 09:10 AM
1000gade
May 27, 2015 12:37 PM
