gio 110 wont start help!!
Old Jun 11, 2012 | 12:09 PM
motorhead67's Avatar
Default gio 110 wont start help!!
hi everyone,
we have a brand new gio yk110 which runs great but only starts when i put a scewdriver accross the terminals on the starter solenoid so had a new solenoid sent from the dealer we bought it from
its exactly the same ! so have been told it is the actual starter switch
had a new one sent still the same
it runs great but a real pain in the *** and the kids are freaking
any ideas or help would be happily received!
thanks
p.s also have an older one that has now developed the same problem!
Old Jun 11, 2012 | 04:53 PM
Jaster94's Avatar
engage the left handlebar brake!. i think your quad has the safety interlock so kids don't run over themselves inadvertantly or the quad just takes off on its own when started. if your brake light bulb is broke and your brake switch won't illuminate it, that doesn't mean your switch is broke. you should hear a small "tink" up on the left area of the handlebars, that tells you the switch is activating. try that and let us know.
Old Jun 11, 2012 | 11:14 PM
LynnEdwards's Avatar
Electrical Expert
I second Jaster94's post .
Old Jun 12, 2012 | 08:43 AM
Hi guys yes the safety brake is on and i checked the switch works but still no start! **** ! lol
thanks for the help tho'
Old Jun 12, 2012 | 10:45 AM
Jaster94's Avatar
ok, need you to start chasing a loose wire from the starter button down to the solenoid/fuse area. the small gauge wire can be either kinked, cut, grounded out, or just loose and not connecting. let's start there if everything else was good.
Old Jun 12, 2012 | 11:06 AM
you guys are great! i have even changed the starter switch and wiring for another new one but will check everything again ! thanks everyone
Old Jun 12, 2012 | 11:09 PM
Electrical Expert
I believe this is the wiring diagram for a Gio 110cc:
See if it matches yours. Does this quad have a remote module?
1) Turn on the ignition, and apply the brakes. Measure the DC voltage using the 20 volt scale on both the small starter solenoid wires. These are the wires that activate the solenoid and connect the big screw terminals. What do you measure on each small wire?
2) Repeat the test, but this time with the starter button pushed while taking the measurements. What do you measure on each small wire?
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
