Cleaned carb and still dies when given gas
Old Jun 28, 2012 | 02:16 PM
95wolv's Avatar
You could pull the air box and look into the carb inlet while you open the throttle while its running to see if the slide lifts,that would tell you if the diaphram is working. if the slide goes up, and it still dies, you have a blocked fuel passage, and the motor is starving for gas ,so it dies when you rev it, pulls in air, but no extra fuel, bogs out.
Old Jul 1, 2012 | 11:53 AM
ezhoops's Avatar
Ok, recleaned up everything and watched the diaphram rise when i pushed the throttle. I dont know how it could be starved for gas when i cleaned the jets twice in a week. I used a wire and compressed air o clean them out.
Very frustrated with this.....
Maybe i missed something to clean, the one thing i noticed is when i loosen the air/fuel screw it will slowly tighten back up from the vibration of the atv.
Any ideas before i break down and buy a repair kit or new carb from one of these places
http://www.amazon.com/CARBURETOR-GY-...d_sim_sbs_sg_5
Or this repair kit
Carb Repair Kit - Carburetors - 150cc GY6 4-stroke - PartsForScooters.com Store
Old Jul 2, 2012 | 08:48 AM
RonV's Avatar
When's the last time you adjusted your valves?
Old Jul 2, 2012 | 11:07 AM
ezhoops's Avatar
Never and dont know how. Can you explain?
Old Jul 2, 2012 | 11:28 AM
  #15
RonV's Avatar
Scooter How-To : GY6 Valve Adjustment (Also For Buggy + Kart) - YouTube
Old Jul 2, 2012 | 02:44 PM
  #16
ezhoops's Avatar
This might be beyond my skill level. Where can i buy a feeler guage
Old Jul 2, 2012 | 02:55 PM
  #17
RonV's Avatar
It's not that hard. You can get a feeler guage from most cycle shops. I never took the right side cover off. I just took the valve cover off, then got the cam in the position as shown in the video and adjusted from there. You'll want to take out the spark plug so you can turn the motor over easily. That video is pretty much spot on regarding how to do it.
Old Jul 2, 2012 | 05:54 PM
  #18
ezhoops's Avatar
But do you really think that could be the issue?
Old Jul 2, 2012 | 06:16 PM
  #19
RonV's Avatar
I don't know for sure, but I know these things are tough to start and run rougher if the valves are not set properly.
Are you sure you are getting plenty of fuel into the bowl? Possibly your float needle is sticking closed? Again, I'm just throwing stuff out there.
Old Oct 23, 2018 | 04:54 PM
  #20
Matt Giordano Yoga's Avatar
Default Carb spring
I have a kazuma 250 and it sat all winter. I cleaned carb, starts great but when i give it gas it dies out everytime. I tried adjusting the carb fuel screw wih no luck. I loosened it till it was rattling.
Please help, i'm getting frustrated with this thing.
ao I had this issue as well - I read this and then took my carb a part a bunch of times. Turns out I put the sping that holds the lid down under the diaphragm instead of on top and that was my issue.
honda71
Jul 12, 2015 05:56 AM
honda71
Jul 8, 2015 02:13 AM
tweeder
Jul 5, 2015 01:57 PM
ranvette
Jul 4, 2015 06:13 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
