wiring problem
Dear expert I own a 110 viva chinese quad made by the Kangchao company china. On the starter relay assy. , it has two small wires coming out the top,one is yellow with a red stripe with a female end and the other one is a light red with a male end. I had to replace it and can't remember how they hooked up and have searched everywhere on the harness. I will be forever grateful if you can help me with this problem.
Thank you,
May
Thank you,
May
Thos two wires plug into the starter interlock wiring. There should be wires nearby to connect to - since I assume this was hooked up and working at one time. Is this correct? The wire colors may not match up to the wire colors in the harness.
Look around for loose wires in the vicinity of the starter relay (solenoid). If you find some loose wires what are their colors?
