Roketa Intermitent spark turned no spark
Old Sep 12, 2012 | 01:39 PM
Brian J's Avatar
Default Roketa Intermitent spark turned no spark
I have a Roketa 400 atv and intermitent spark has turned into no spark. my cdi looks diferent than others i've seen on posts here it is 5 wire. the connector is on a wire coming out of the cdi not on the cdi its self. there are three pins on top and two below them. is the kill switch wire the center pin on the top row?
Also I have a red light that comes on on a box that looks similer and is mounted by the cdi called the carborator controller. I havent noticed the light on before however in comes on now when turning on the key. Is this normal?
Old Sep 15, 2012 | 12:38 AM
LynnEdwards's Avatar
Electrical Expert
I know absolutely nothing about this quad. In your manual did they provide a wiring diagram? I don't have one in my collection.
Can you post a picture, or a link to a picture of the CDI you have?
Old Sep 19, 2012 | 10:56 AM
Brian J's Avatar
Default Fixed
The red light I found is normal. I replaced the CDI. That fixed it. The Roketa-ATV11 RTU-400Y is the same as a Jianshe-js400
Thanks
Old Sep 19, 2012 | 10:56 PM
Electrical Expert
Good info. Thanks for reporting back, and I'm glad you got it running...
bzdok1234
30
Feb 23, 2016 01:55 PM
Countrygirl1976
Jul 13, 2015 10:08 AM
Unzzy66
Jul 11, 2015 10:01 PM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
