Taotao 110 cc no spark
Old Sep 13, 2012 | 10:05 AM
wilsonmk47's Avatar
Default Taotao 110 cc no spark
Bought this in 2007. No problems til last week. Kids were riding and it quit running. Hasn't started since. I'm pretty stupid when it comes to these 4 wheelers. I have checked spark plug , no spark. i put a test light on all 5 wires coming out of motor from stator. All showed spark except green, I'm assuming it is ground, and the blue and white wire did not show spark. According to diagram I have of cdi, that wire goes to timing trigger. Any ideas?
Old Sep 13, 2012 | 11:03 AM
Jaster94's Avatar
so you have no fire signal on the coil wire, right? , does it have a rear tether kill switch? did it activate? i presume all quick connects are connected and you did a tug test on all of the wires at the CDI on the connectors? have you tested the kill switch on the left handlebar to make sure it ain't killing the spark?
Old Sep 13, 2012 | 11:22 AM
wilsonmk47's Avatar
I disconnected kill wire from cdi then pluged back in and tried to crank. still nothing. It will turn over but want start.
Old Sep 13, 2012 | 11:24 AM
wilsonmk47's Avatar
how do I check kill switch on handle bar?
Old Sep 13, 2012 | 11:26 AM
Jaster94's Avatar
just curious cause you haven't stated this: but have you tried a different spark plug? i've had no spark conditions before on some quads, changed the spark plug to the comparable NGK and BAM, had spark. it's worth a try.
but you may need to check out what i listed earlier unless you already ruled them out as culprits.
Old Sep 13, 2012 | 04:16 PM
wilsonmk47's Avatar
I can't believe it but it was a $2.13 spark plug. thank you. I sure thought it was something more complicated.
Old Sep 13, 2012 | 08:27 PM
Jaster94's Avatar
glad you got it running. now keep a spare plug around in your toolbox and have fun riding around. now the kids will know you're the hero.
Old Sep 13, 2012 | 11:27 PM
LynnEdwards's Avatar
Electrical Expert
Good Job Jaster94 .
pgamboa
Dec 24, 2023 11:52 AM
fordfaithful21
Dec 7, 2015 05:52 PM
Slagpolaris
Sep 5, 2015 09:41 PM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
vtech
Help With Forum Software!
Sep 2, 2015 05:59 PM
