125 TaoTao no start update
Old Oct 27, 2012 | 07:50 AM
spits's Avatar
Default 125 TaoTao no start update
It started and ran fine. Finally. The culprit was a loose wire connection in the connector from the stator wires to the harness. Sometimes we tend to over analyze things instead of the simple things. I should have known better as we have come across numerous wiring problems on the Tao Tao bikes. After checking out the specs on the coil, stator, cdi, checked out the kill switch, etc,etc., SEVERAL times...... I went back to basics and started on the harness and plugs for continuity. Ended up finding the bad wire by a mistake I made in wire colours.ANYway long story short I have to date not had a bad stator cdi or coil go bad. Remote start, and one starter, yes but only one of each. This is not to say it won't happen because with all the electrical questions it does. So check the simple things(connections) first. Don't learn the hard way like me who should have known better.
Old Oct 27, 2012 | 04:42 PM
Jaster94's Avatar
neilbedwell
Nov 10, 2018 11:02 AM
cornermike
May 28, 2015 09:47 AM
1000gade
May 27, 2015 12:37 PM
elmer119
May 24, 2015 10:51 AM
