will these rims fit ?
Old Dec 26, 2012 | 03:08 PM
maddyx's Avatar
Default will these rims fit ?
hey everyone i have a question i was wondering if anyone can assist me with i have a kazuma falcon 110 that im fixing up and i was wondering if the rims from a yamaha raptor would be able to fit it ?
Old Dec 26, 2012 | 09:26 PM
mudmike's Avatar
Default your gonna have to yank your wheels and measure
first the rim size this is printed on the tire itself for example on my ATC185 I run a 25x13x9 on the back this means the tire is 25 inces tall 13 inces wide and has a 9 inch hole in the center you need the last number.
Next yank the wheel and assuming it has 4 lugs measure across the rim (2 bolts apart) and measure the holes center to center.
Finally you need to measure width of the rim itself (not the 13 on my tire) Best way to dl this with the tire on is take a straight edge place it across the tire now measure through the big hole to the straight edge. Next measure from the straight edge to the lip on the rim (right nest to the tire) on both sides and subtract those 2 measurements from the first. On my trike I got 13.5 for measurement 1 then 2 1/4 to the lip on each side so 13.5-2.25-2.25=8 inch rim
I'll post a link I found so you can cross reference your findings
they are listed like 9x8 the 4x110 the first set is the physical size of the rim 9 inces tall and 8 inces wide the second number is the holes
Old Dec 26, 2012 | 09:29 PM
mudmike's Avatar
for example 4 holes 110mm apart (just used a common one yours are probably 110 but make sure cause 115 is common too)
Hope this helps
ATV Tire and Wheel Application Chart : ATV Tires Free Shipping : ATV Wheels : Mud-Throwers.com
Old Dec 27, 2012 | 06:02 PM
maddyx's Avatar
ok thanx man much appreciated i asked the question because its hard to find a tyre to fit my rims where i live so i wanted to run rims from a raptor as the tyres are easier to come by thanx 4 the info much appreciated
Bratman2
Aug 6, 2022 01:42 AM
STLyamwar
Jul 25, 2020 04:44 AM
fd24
Jan 16, 2019 08:59 AM
PinkFloydEffect
Sep 25, 2015 06:31 PM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
