110 electrical problem
Old Feb 17, 2013 | 09:58 AM
ageihl's Avatar
Lynn, Thank You so much for all your knowledge and advice. I did the two toggles and turns out that alarm system drains the battery when not in use. I just pull the fuse then no more problems. Thank you again for all the help!!! Take Care!!!
Old Feb 18, 2013 | 08:13 PM
LynnEdwards's Avatar
Electrical Expert
Yes, remotes are a constant drain on the battery even when the ignition switch is off. This has to be since the remote must always be "alive" to receive the radio signal that says 'turn on the quad' even though the ignition switch is off.
But the current required to keep the remote module 'alive' varies widely from brand to brand. Some draw as much as 10 mA (0.01 amps), so this would completely drain a 5 amp-hour battery in:
0.01 amps = 0.24 amp-hours per 24 hour day
5 amp-hours @ 0.24 amp-hours per day = 20.8 days.
So your battery will be completely drained in just under three weeks - if you have one of these really inefficient remote modules. When buying these remote modules there is no information on standby current consumption so there is nothing to go on.
Your idea of removing the fuse for storage is a good one...
Old Mar 22, 2013 | 11:34 AM
armagh's Avatar
LynnEdwards knows his stuff.
skinnyr6
Aug 25, 2023 02:18 AM
TheHood
Jul 26, 2015 09:51 AM
Chuck188
Jul 17, 2015 02:45 PM
Unzzy66
Jul 11, 2015 10:01 PM
ranvette
Jul 4, 2015 06:13 PM
