Help please chinese 250cc problem
Old Jan 16, 2013 | 04:40 AM
yaza01's Avatar
Default Help please chinese 250cc problem
Hi, my 250 cc quad is playing up, my brake switch works fine but brake light bulb does not illuminate, i know its working because of i try to start without my foot on the brake it will not start.... Iv checked bulbs there fine, they do light up when lights are on but when full beam is on they come off but regardles the brake light wont work when braking...
Problem 2
my atv does not run longer than 30 secs, but when quick start sprayed it will idle for 2mins then die out, if i rev it it dies out regardless, what could be the problem?
Thank you for anyhelp
Old Jan 16, 2013 | 05:33 AM
mudmike's Avatar
"Problem 2
my atv does not run longer than 30 secs, but when quick start sprayed it will idle for 2mins then die out, if i rev it it dies out regardless, what could be the problem?"
How long has it been doing this? Just recently since weather got cold? Does choking it a tiny bit help? If either of these are true you may just need to adjust your air/fuel screw on your carb.(There's a how to sicky on chinese forum) Otherwise sounds like either a dirty carb or an air leak. Get the thing 'running' and spray some starting fluid around the base of the carb and on your intake and listen for a change in engine speed. Dont spray it in the carb cause that will cause a change in engine speed. If your engine changes speed you got air leak if not you got a dirty carb.
Also sounds like you got a bad bulb the brake light bulb has 2 filiments in it. One for brakes one for the tail light. Just cause the tail light comes on when you turn your headlights on doesn't mean the brake light filiment isn't burt out.
Old Jan 16, 2013 | 02:03 PM
yaza01's Avatar
HI THANKS FOR YOUR REPLY..
Iv tryed adjusting the screw on the carb it dont make no difference...
I will try the leak test an update you
The bulb iv checked both filiments they looked fine?
Il try a new bulb if that dn
Old Jan 16, 2013 | 02:07 PM
yaza01's Avatar
Il try a new bulb if that dnt work
An yes its been doing this since the cold weather
There is a vaccum hose at the bottom of the carb which is blocked off by a bolt on it... I have no idea where this goes..
Also my rev meter dont work... What should i check for
Thanks very much appreciated
Old Jan 17, 2013 | 04:55 PM
mudmike's Avatar
The weather changed enough round here I finally broke down and adjusted the needle on the bottom of the slide. That is a pretty drastic tweek though. I'd make sure there is no air leaking and that the carb was clean enogh to eat off of first. Also when cleaning the carb don't forget to remove the air/fuel screw and clean that passage too.
Firefighter400
Oct 8, 2022 06:38 PM
Frisky2050
Apr 9, 2020 11:19 AM
greg74
Sep 10, 2019 03:03 PM
Waddell4436
Technical and How-To Articles
Jul 19, 2015 04:22 PM
Unzzy66
Jul 11, 2015 10:01 PM
