Starter struggles to turn engine over.
Old Jan 5, 2023 | 09:43 AM
  #51
aberwald's Avatar
Originally Posted by merryman
As I wrote above, good connections on the thick wires, including earths are vital. You wrote that battery and starter are good, how do you know?
replaced starter and tested battery
Old Jan 6, 2023 | 03:39 AM
  #52
Have you tried the plug still in but plug lead off test? This tells you if the ignition timing is causing the problem. Unlikely as, if the flywheel is out, it is usually well out and yes, I know you would have removed it to fit the new clutch. It is just possible for a new starter to be bad, I have had a few where internal bad connections have led to a "lazy starter". My guess is something you think you have fixed, or tested to be OK, isn't.
2x_lung
1) Engine problems..
48
May 24, 2023 05:22 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
merryman
Jun 15, 2015 02:36 AM
clsharky
Jun 8, 2015 11:38 AM
vipers
May 31, 2015 09:12 AM
