Xmas present revs on it self n cuts out when reved
Old Jan 19, 2013 | 02:44 PM
Bobski 1980's Avatar
Default Xmas present revs on it self n cuts out when reved
I have a 49 cc Chinese quad , when I brought it it started fine I put it away for Xmas n had trouble starting it after , I drained the bowl n put fresh fuel in and got it going we went out n broke pull start so now we use electric start which hardly ever works so I buy a new battery still we have a problem except when it starts its trying to drive off at high revs so I pik the bak wheels off the floor and they just spinning really fast I rev the quad and its cutting out next I've looked in carb and float is ok and freely moving ,I've messed with air screw n can't seem to stop it revving so high pls Hlp!!!!
Old Jan 19, 2013 | 03:39 PM
mudmike's Avatar
That sounds like a vacuum leak. Check to make sure you didn't knock a rubber line off somewhere. If not grab a can of starting fluid and spray any rubber lines, wher the carb meets the boot, boot to intake (or carb flange if yours doesn't have a boot), intake, and intake to head. If the engine changes revs then you found the leak. Simply disassemble and find out why (bad gasket/o-ring, loose bolt, ect...)
Joe454
Nov 20, 2020 01:19 PM
Alex G.
Sep 11, 2017 11:38 PM
Beeline08
Nov 11, 2016 04:00 PM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Bernhard
Sep 25, 2015 12:45 PM
