TAOTAO 250 hard to crank
Old Mar 23, 2013 | 02:44 PM
tgolds's Avatar
Thanks Jaster. I will go see if Harbor Freight has that tool.
Old Mar 23, 2013 | 03:02 PM
Jaster94's Avatar
don't forget some aerosal carb cleaner either! that helps too!
Old Mar 26, 2013 | 10:51 AM
mudmike's Avatar
Originally Posted by Jaster94
there's plenty of other atv carb videos you can search on, but that one gives you the basics. i personally use the oxy-acetylene torch tip cleaner pack to rod out the orifices.
They actually make a set of tip cleaners that look like tiny drill bits. They come in a tool approximately the size of a pen. It has like a little drill chuck at one end. Around here they run like 11 bucks (though mine always seems to get lost about the time my friends "find one laying around" for free)
I love the drill bit style cause I tend to take in old forgotten machines and they make cleaning the jets that have been plugged for years alot easier.
Old Mar 26, 2013 | 06:22 PM
Jaster94's Avatar
do you have a pic? model number? manufacturer name? HF stock number? i've searched the internet and HF and cannot find it for some reason. i'm interested in that little tool! i presume that when one is careful, they won't ream out the orifices?
Old Mar 27, 2013 | 09:42 PM
  #15
mudmike's Avatar
I usually pick them up at a local welding supply shop but found these on Amazon
Forney 86140 Tip Drill Set with Extra Drills - Amazon.com Forney 86140 Tip Drill Set with Extra Drills - Amazon.com
The only difference I see is mine the end near the clip unscrews to allow access to bit storage leaving the 'chuck' end mounted solid.
Some of the tips are so tiny they easly fit through the little holes on the side of a jet
Old Mar 28, 2013 | 06:56 AM
  #16
Jaster94's Avatar
hot dang, i'm gonna get 2 of them bad boys. they ought to be a whole lot better than the oxy/acetylene torch tip cleaner packs. well, at least sturdier! thanks a bunch! looks like i'll stop by the welding supply place next time i'm in the big city.
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
GODsRebel
11
Sep 8, 2015 12:07 AM
Slagpolaris
Sep 5, 2015 09:41 PM
Pahuntman
Sep 5, 2015 11:07 AM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
