No Spark Diagnosis
Old Apr 8, 2013 | 06:53 PM
lindy161998's Avatar
Smile No Spark Diagnosis
Im trying to fix up this bashan (gorilla) 200cc atv and im not getting any spark, i got a brand new ignition coil, and brand new solenoid, and neither of them did anything new. Im stuck on what to do now. Any sugguestions?
Old Apr 9, 2013 | 05:58 AM
Jaster94's Avatar
so i'm presuming it cranks/turns over? ok, sometimes just a new NGK spark plug does the trick, BUT, have you checked the kill switch on the left handlebar with an ohm meter/multimeter to make sure it's working correctly? is that "on/off/on" or "run/kill/run" switch working correctly? i'd trace the wiring back from there and the keyed ignition switch to make sure there were no wiring deficiencies such as kinked/broken/pinched/exposed wiring that could ground out or has broken in half. that's a start anyways.
fordfaithful21
Dec 7, 2015 05:52 PM
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
MrTrashMan2U
Sep 9, 2015 11:11 AM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
