125cc shifts hard
Old Apr 24, 2013 | 02:49 PM
Loki1000rr's Avatar
Default 125cc shifts hard
hello everybody. Just picked up a 125cc peace sports I think. Ran good after a carb clean, rode it for about 2 hours an friend smoked clutch! so i replaced it! now it shifts hard an I cant figure it out!!! Some advice is needed! p.s. adjustment srew wont turn.
Old Apr 24, 2013 | 04:08 PM
Loki1000rr's Avatar
It is really P'n me off as it shifted fine before I installed clutch! time to pull it apart again! m
Old Apr 24, 2013 | 08:02 PM
The_Mechanic89's Avatar
is it centrifugal style clutch? like the honda e22? if so just swap the clutch discs from the new clutch to the old one with the softer springs
Old Apr 24, 2013 | 08:52 PM
Loki1000rr's Avatar
Thank you, I got more interested as to what was going on... soo I took the cover of! the clutch un screwed off the shaft???? can not figure out how??? Put it back together an fingers crossed!
Old Apr 25, 2013 | 01:19 PM
Loki1000rr's Avatar
So its shifting nice! But.... sounds like the spanner nut came off again????? Is it usually loud when its new or is my suspicion right? At this point its a matter of why! I know that it was secured (the weird washer that you bend a tab into the nut)??? Has this ever happened to anybody? Am I just retarded?
Old Apr 26, 2013 | 07:43 AM
Loki1000rr's Avatar
Happened again!!!! Now I'm lost, looked at everything, no wear out, no missing parts, no broken parts! Now what?
Old Apr 27, 2013 | 09:37 AM
Loki1000rr's Avatar
running good shifting like a beast! Gonna check it once more.
Old Apr 29, 2013 | 09:36 PM
yes i had this happen to mine the nut bottomed out prematurely and i realized i had lost a washer between the nut and the locking tab washer. i installed a decent thickness washer and re tightened the nut and there was no more grinding/whining noise from the clutch
akguy31
Aug 31, 2019 04:34 AM
Ridgerunner665
Sep 15, 2015 01:20 AM
essonlaker
Sep 10, 2015 01:12 PM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
Elkaholic
Sep 6, 2015 02:44 PM
