110cc Coolster Chinese Gokart starts fine warm But!!!
Old Apr 24, 2013 | 11:33 PM
Padawan's Avatar
Default 110cc Coolster Chinese Gokart starts fine warm But!!!
When i turn the ignition on it cranks and cranks like it wants to start and fter about 10 minutes it finally starts after it warms up from the cranking. I put i in drive and it sputters when flooring the gas but when i back off it goes better but have to keep giving it gas or it stalls. Are these problems related to the carb or is it 2 different problems.
Thanks in advance for any help.
Old Apr 25, 2013 | 07:40 PM
Jaster94's Avatar
clean the jets in the carb.
Old Apr 25, 2013 | 08:15 PM
Padawan's Avatar
Thanks Jaster94, I will give that a shot and report back!
Old Apr 25, 2013 | 08:47 PM
Jaster94's Avatar
your choke may be malfunctioning also. unsure right now. but it does sound like a fuel delivery issue which would point to the jets.
Old Aug 12, 2014 | 09:21 PM
Padawan's Avatar
Back again a year later, I finally got around to getting the carb rebuilt it cost me just over $100. I put the thing on and the motor is doing the same thing maybe just a bit better but not much. What else could i try? Where would a choke be located on one of these machines. Or could it be a CDI? I posted a link to the motor that's in it.
Old Aug 13, 2014 | 09:37 AM
Zrock's Avatar
Super Quad Patrol
did you rebuild yourself or have a shop do it? it you had a shop do it why did they not set it up and make sure it was running properly. The carb probably needs to be set properly. Cannot see your link but would be help full to see pic's of your actual unit
Old Aug 13, 2014 | 09:42 AM
Swiftyyy's Avatar
Like Zrock said, you should locate the mixture screw and fiddle around with that (there is a guide on this forum).
Your issues do really sound like carb related issues.. My ATV did start acting similarly to yours and the CDI was getting a bit warm, but just turning the ATV off and re-plugging the CDI mended the problem.
Also, when you're starting it, try holding the throttle in a little bit. Mine starts, but certainly not as smoothly if I don't give it a little bit.
Old Aug 13, 2014 | 09:58 AM
Padawan's Avatar
I had a shop do it. The guy said he had set it to factory settings so i don't know if that is compatible with the motor.
I will check the cdi also.
Thanks!
Old Aug 13, 2014 | 09:59 AM
Padawan's Avatar
Thanks Swiftyyy, I will give that a try.
NickNAsh
Mar 6, 2018 06:12 PM
dmages68
Jun 14, 2015 05:16 PM
Scott-Leigh
Jun 6, 2015 09:10 AM
1000gade
May 27, 2015 12:37 PM
RaymondT
May 26, 2015 08:14 PM
