New guy here , need a little help
Old May 3, 2013 | 05:38 PM
vulgarwolf's Avatar
can see the kill switch on the handlebars, its not close enough to see if there is a start button!!!
Old May 3, 2013 | 05:41 PM
NRXTM's Avatar
this might be disappointing to you but , i dont think i can fix it im gonna sell it on sunday
Old May 3, 2013 | 05:47 PM
vulgarwolf's Avatar
You said you are 16, you are young and the best age to learn new things, I got my first bike at 15-16 replaced clutches, pistons and things, the feeling of achievement of making something work and knowing you did it is the best feeling around, unfortunately when I was 16 back in 1991 there were no forums like this for advice so a lot of it was hit and miss.
I urge you not to give up, I have seen it many times, friend has bike, bike doesn't work, sells to other friend, he gets bike going, first said friend is sad.
If you take the seat off can you see a solenoid, looks like a round barrel with 1 wire going to either side and then there will be 2 other wires that run to it together. there wires that go either side should be thick, 1 will go to battery and 1 will go down to starter motor, if you want to go and have a look now I will guide you through some basic troubleshooting, its only 9 am here in Australia atm and I am not going anywhere till 11 am
Old May 3, 2013 | 07:06 PM
NRXTM's Avatar
Uploaded with ImageShack.usUploaded with ImageShack.us
here are some pics under the seat , i dont see the round barrel thing
Old May 3, 2013 | 07:12 PM
  #15
vulgarwolf's Avatar
follow the red thick wire, can you see the starter motor
Old May 3, 2013 | 07:21 PM
  #16
vulgarwolf's Avatar
where the fuse holder is, that's the fuse for the main running of the bike, there should be a thicker wire that runs down to the starter motor, it will either be on the top of the motor or bottom,
Old May 3, 2013 | 07:28 PM
  #17
NRXTM's Avatar
i just found the start button it was under the kill switch. i should have looked for the start button better earlier now i think i dont need the ignition anymore. and i think i found the fuze holder , is it just a small black box? ill take off the body and see if i can find the starter tomorrow
Old May 3, 2013 | 07:30 PM
  #18
vulgarwolf's Avatar
the fuse holder is that white plastic thing in your second pic, you will need a battery in there to start it
Old May 3, 2013 | 07:38 PM
  #19
NRXTM's Avatar
yep the battery is dead and in my room would an auto zone charge it for me?
Old May 3, 2013 | 07:42 PM
  #20
vulgarwolf's Avatar
not sure what auto zone is, shops don't generally charge them for people, a battery charger will do it, there is also the possibility the battery is dead
