Engine idles but 'bogs down' under load
Old Apr 30, 2013 | 12:34 PM
golfprorich's Avatar
Well this evening I put an NGK plug it and started straight away and ran sweet. 1st gear could be engaged and you could pull away with just feathering the throttle, and that was with me on it
Then, as it was idling before putting it away it just cut out and wouldn't restart.
Plug out and no spark whatsoever
So now I have to locate whats causing the no spark. I guess the first thing is to look at kill switch wires, anyone in particular can it be tested with a multimeter?
Old Apr 30, 2013 | 03:08 PM
Jaster94's Avatar
yeah, check all of your kill switches with your ohm meter/multimeter. that'll help you narrow it down quickly. glad it ran for a bit.
Old May 1, 2013 | 02:48 AM
I take it the kill switch gives a 12v to the starter relay and the coil, any idea which wire does which?
Old May 2, 2013 | 06:01 AM
Well fingers crossed I think I have sorted it
It started on the button this morning butI noticed that when I put some weight on the right hand handlebar it started to want to cut out.
So I thought some wiring must be getting aggravated somewhere and I soon narrowed it down to the safety cut-out switch on the left hand side of the engine. When I wiggled the wires on that again the engine wanted to cut out.
So I snipped the wires and connected them up, taking out the switch. Now no matter what movement I do on the quad there is not cutting out, result!!
Cheers for all the help
Old May 2, 2013 | 03:25 PM
  #15
Jaster94's Avatar
that's dang good news!!!!! have a good'en!
Old Dec 30, 2016 | 10:28 PM
  #16
Joshua Campbell's Avatar
as your slide or butterfly on your carb opens, the lower pressure sucks in more air as more gasoline is sent to piston via the carb. the carb is trying to maintain the ratio. when it bogs down when the throttle is pressed, you're demanding more fuel, right? well, with a partially clogged/plugged jet, the gasoline demand is not met BUT you still have more air coming in offsetting the ratio. NOW, fuel demand is not met to sustain the burn and the quad bogs. does that make sense? hope so, i got cramps from typing. but anyways, that is a fuel delivery issue that needs to be rectified. to test for vacuum leaks at the intake boot, let it idle, spray carb cleaner or ether-starting fluid around the outside of the intake boot-not the airbox side. if it revs up, you have a vacuum leak that sucked in the vapors and fed the piston downstream of the carb. could be as simple as making sure the flange/O-Ring is on correctly or replacing the intake boot.
I think I may agree with you on this one for my situation , because my bike is bogging out huge when I push the throttle in fast , but if I go slow and steady at up to half throttle it it seems okay but the faster I go and the more I push past half way , it gets jerky and sputtery .
Old Dec 30, 2016 | 11:22 PM
  #17
the only seal I haven't replaced after the rebuild was on my intake boot on the cylinder head I did the carb end , I'll see what happens tmrw after a test with brake cleaner maybe on to the boot at mating surfaces at idle , or I'll just replace it anyways since I have the seals to do it with ....
Old Sep 12, 2018 | 02:46 PM
  #18
alo's Avatar
alo
jaster94 checking for air leaks posted 4/28/13
Do not spray 'ether' or 'quick start' any where near a hot engine or exhaust pipe. Brake cleaner is also combustible.
Old Sep 23, 2019 | 03:51 PM
  #19
Josh Burdette's Avatar
it's not the CDI, put it up on blocks and tie it down or hang the rearend from the ceiling. start it and rev it up with the rear axle off of the ground, does it do the same thing? does it do it in neutral? if in gear and it does it, may start looking at clutch, if it does it in neutral, it's a vacuum/fuel delivery issue like a partially clogged main jet.
My kodiak is doing the same thing revs fine in neautral and in gear as long as the tires are off of the ground but want get over about 15 20 with a load and it starts sputtering if I gas on it but if I ease into the throttle it will gradually increase in speed
Old Sep 23, 2019 | 04:08 PM
  #20
LT80's Avatar
LT80 Expert
Did you clean the carb?
