E22 honda, lifan, locin, bmx, all clones. Complete tear down (lots of pics)
Old Apr 29, 2013 | 08:43 PM
The_Mechanic89's Avatar
Talking E22 honda, lifan, locin, bmx, all clones. Complete tear down (lots of pics)
Well i couldnt find a build/tear down thread for any of the E22 engines so i figured id make one. this is a true E22 honda engine with clone covers.[/COLOR]
well here goes...
CAM00932_zps8b656bcf.jpg?t=1367284703
First i removed flywheel side casing. then i removed tensioners for the starter chain giving me enough slack to remove the starter.
FLYWHEEL SIDE
CAM00933_zps40fc8a59.jpg?t=1367284714
TENSIONERS/CHAIN/STARTER REMOVED
CAM00934_zpsb2273d31.jpg?t=1367284721
I then removed the valve cover, the side cover, and cam chain cover[/COLOR]
VALVE COVER
CAM00935_zps88a45a2b.jpg?t=1367284781
SIDE COVER CENTER BOLT HOLDS CAM SPROCKET COVER ON OPPOSITE SIDE
CAM00936_zps9beef564.jpg?t=1367284781
CAM00937_zpsbdce98d4.jpg?t=1367284781
CAM00938_zps41832e5b.jpg?t=1367284781
not sure if i should post so manny pics lol but i have most of the tear down in piece by piece pictures. i kno some people with older computers would hate loading this thread if i do so
ALL PICTURES ALSO HERE WITH SOME VIDEOS
Old Apr 29, 2013 | 09:05 PM
Ok continuing on......
TIMING MARKS
CAM00939_zps8e537b0e.jpg?t=1367284781
ANYONE KNOW WHAT THE MARKS MEAN?
Remove these three cam sprocket bolts then gently remove sprocket allowing it to drop into the cylinder head. Don't worry it will fit through. Then loosen and remove the rocker covers/caps to expose the valve/valvespring/rocer end and loosen the lock nut and back out the valve lash stud untill there is slack in the rocker arm IF YOU ARE REMOVING YOUR CAM THAT IS
CAM SPROCKET
CAM00940_zpsd80c3a14.jpg?t=1367284781
CAM SPROCKET/CHAIN
CAM00947_zpscd529585.jpg?t=1367284781
CAPS
CAM00946_zpsef35cf60.jpg?t=1367284781
LASH BOLTCAM00941_zpsc34fc5ec.jpg?t=1367284781
CAM00943_zps6c193055.jpg?t=1367284781
Once you have all the bolts removed you can then reomve the cyilinder head
CYLINDER HEAD/VALVES
CAM00948_zps674dc72d.jpg?t=1367284781
CAM00949_zps27f9da4d.jpg?t=1367284781
Then remove the small bolt on the side of the cylinder head and remove the cam chain guide wheel
CAM00950_zpsa75535bb.jpg?t=1367284781
CAM00951_zpsd2cdb74c.jpg?t=1367284781
CAM SPROCKER/GUIDE
CAM00952_zpsae0a568e.jpg?t=1367284781
CAM CHAIN VIEW DOWN CYILINDER INTO CASE
CAM00953_zpsc2a4fde7.jpg?t=1367284805
You can then pull your cylinder up but not off as to prevent fighting with the rings later you can but it is not necessary. also loosen the head/cylinder bolts so they're ready for later
CAM00954_zpsa638f712.jpg?t=1367284805
CAM00955_zps7b53d063.jpg?t=1367284805
CAM00956_zpsb2ecd4df.jpg?t=1367284806
CAM00958_zps7209d93a.jpg?t=1367284806
Old Apr 29, 2013 | 09:31 PM
ill continue later on. right now im trying to figure out the best way to remove the magnetic flywheel
Old Apr 29, 2013 | 10:01 PM
<embed width="600" height="361" type="application/x-shockwave-flash" allowfullscreen="true" allowscriptaccess="always" wmode="transparent" src="http://static.photobucket.com/player.swf?file=http://vid1365.photobucket.com/albums/r746/The_Mechanic89/E22 TEARDOWN/CAM00989_zps3ea0638e.mp4">
this is the problem with my trans 2nd to 3rd jamms
Old Apr 30, 2013 | 09:23 PM
keithert's Avatar
My parts atv came with a basket case engine so I've taken some of the head off and the trans cover off. I haven't had to get it actually running though.
Old May 1, 2013 | 02:35 AM
well the engine and trans is disassembled haven't had enough time to continue the thread yet. still i'm unsure as to why it jambs up i flipped the shift forks as they were worn on opposite sides of each other.
wouldn't mind a parts bottom end that blew on the motor side with an intact trans. my plan is to taper the edges of the straight cut gears n taper the engagement pins on the gears for ease of shifting between gears.
i think the issue is more or less in the internal shifting armatures or the shift fork spool. so i will try my best with whats here and see how it goes. i've got a feeling ill be buying a spare E22 possibly a clone for parts or use.
Old May 1, 2013 | 08:39 PM
Durby's Avatar
that looks VERY similar to an old 88 Yamaha Moto4 100cc that I used to own.
Old May 2, 2013 | 10:10 PM
hmm ill have to check that out may be another i can use parts from but mine is a genuine honda E22 engine theres tons o companies using this engine and slappin their bands on them basically. Honda's pattent on their early engines ran out so everyone starting making them including this engine the E22
hugemoth
Jul 20, 2020 03:28 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
Mojave250A
Jul 11, 2015 10:38 AM
MNatv89
Jul 7, 2015 11:36 AM
Rider252
Jul 6, 2015 03:37 PM
