Xtreme Tantrum X100 questions
Old May 4, 2013 | 06:40 PM
BrandoB's Avatar
Default Xtreme Tantrum X100 questions
Hey Folks,
I'm new here to ATVC and recently came into an older Xtreme Tantrum X100 atv. Since XtremeATV is no longer in business, I cannot find a lot of information about them. I am also new to Chinese quads so I apologize for my lack of knowledge here. My X100 has a 100cc 2-cycle motor on it and it doesn't quite have enough ooomf when I take my little boy on a ride. He's too young to ride it his self so I was thinking about a possible motor swap. I was looking at maybe swapping to a 125cc motor but didn't know what brands, or if it would be a direct replacement or if modifications to the frame or other parts would be necessary. So in closing:
Can I swap a 125cc 4-stroke or 2-cycle (if they make it) engine into my 100cc 2-cycle Chinese quad? Or is there a big bore kit available? If so, what brand engines or bore kits would you suggest and what mods would be necessary?
Sorry again for my lack of knowledge and thank you for the help. Please let me know if I can answer any questions about the ATV for you.
Old May 5, 2013 | 06:37 AM
Jaster94's Avatar
keys to engine swaps:
dimensions available inside chassis. will the replacement fit?
gearbox/tranny...will it bolt up or is it all one piece?
is the electrical system AC or DC?
motor mounts-will they work or have to be modified?
check the throttle cable adjustments and make sure it ain't governed too much. usually a turnbuckle style adjustment at the handlebar or near the carburetor. sometimes in the middle of the throttle cable. it should have "extra" rubber on the outside like a boot. peel the fat rubber back, adjust the jamb nuts, stroke the throttle, adjust more if necessary, then put fat rubber boot back across adjuster.
double check to see if the thumb throttle has a screw on the backside which also acts as a governor.
points to ponder.
i take it that it is an automatic the way you describe it. one speed? maybe reverse also? you could mod the CVT clutch i reckon.
the engine, which clone is it from? honda? yamaha? polaris?
don't apologize for lack of knowledge. we all started out the same way. that's why this forum is here. to spread the word and wisdom and knowledge.
Old May 5, 2013 | 07:45 AM
BrandoB's Avatar
Hi Jester, thank you for the "inflamed" response. I appreciate the information you've given me to look at. As for determining the engine clone, is there a way for me to determine what clone I'm looking at? There is no reverse that i have found although there was a model that did have it. So far this is All the information I have regarding this machine:
MANUFACTURER Xtreme Motor Co.
MODEL YEAR 2006 (questionable)
MODEL X 100 Tantrum
M.S.R.P. * $1,899.00
DIMENSIONS
LENGTH 50 in.
HEIGHT 37.4 in.
WIDTH 36 in.
WEIGHT 234 lbs.
SEAT HEIGHT 25 in.
ENGINE
ENGINE 2-stroke, reed induction, horizontal 1-cylinder
DISPLACEMENT 97.6 cc
BORE X STROKE 52 x 46 mm
CARBURETION Mikuni AM7 14 mm w/auto choke
FUEL TANK CAPACITY 1.2 gal.
IGNITION AD/CDI w/electronic advance
STARTING Electric w/backup kick
COOLING Forced air
LUBRICATION Metered, direct oil injection
DRIVETRAIN
TRANSMISSION CVT fully automatic V-belt
DRIVE SYSTEM 2x4
BRAKES/WHEELS/TIRES
BRAKES Front and Rear: Drum
TIRES Front: 19-7.00 x 8
Rear: 18-9.50 x 8
OPERATIONAL
SUSPENSION Front: Single A-arm w/nitrogen charged, coil over damper
Rear: Swing axle w/nitrogen charged, coil over damper
LOAD CAPACITY 175 lbs.
Old May 5, 2013 | 10:38 AM
BrandoB's Avatar
I located your guide on VIN reading. It revealed a little information on the quad but not much. I also tried to remove the belt cover on the left side of the motor but the nuts are completely seized. I've rounded one out and have them sitting in WD-40 now. If it helps, I can post the VIN. Determining the type of motor has become quite difficult! Any suggestions?
Old May 5, 2013 | 04:01 PM
Jaster94's Avatar
post some pics on the thread if you can, OR, make an album under your profile and we'll go look there.
Old May 5, 2013 | 04:38 PM
BrandoB's Avatar
I will post some pics on a flickr account and post the link shortly. BTW my response to you earlier meant to say thanks for the UNFLAMED help. Not inflamed response LoL. Didn't want you to think I was being a jerk LoL.
Old May 6, 2013 | 06:26 AM
Jaster94's Avatar
don't worry. it's all good. BTW, here's the definition, so it was a compliment.
in·flame (n-fl m) v. in·flamed, in·flam·ing, in·flames. v.tr. 1. To arouse to passionate feeling or action: Ex: crimes that inflamed the entire community.
Old May 6, 2013 | 02:19 PM
BrandoB's Avatar
Well in that case.... hahaha
Old May 6, 2013 | 03:07 PM
BrandoB's Avatar
OK so here is the link to Flickr showing some pics of the quad. There are also several on there of a vintage (and I do mean vin-tage) trike that I'm restoring. So just disregard those. Flickr: BrandoB Avenger Big Foot Pics' Photostream
Alex G.
Sep 11, 2017 11:38 PM
EIF
Apr 20, 2017 07:15 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
