carburetor issue and needs replacement
Old Jul 13, 2013 | 09:12 PM
  #21
acedriver1997's Avatar
same as before, do you think that the valve might the restricting the gas flow?
Old Jul 14, 2013 | 12:34 PM
  #22
Jaster94's Avatar
it's possible that the petcock valve has got some solids in it restricting the flow. very possible.
Old Jul 16, 2013 | 12:13 PM
  #23
i bypassed the petcock valve with no prevail so i put it back and what do you suppose i do
Old Jul 16, 2013 | 12:26 PM
  #24
do you think that the carb might need an adjustment
Old Jul 28, 2013 | 08:42 PM
  #25
or jaster94 do you think that it needs to be rebuilt
Old Jul 29, 2013 | 06:03 AM
  #26
Jaster94's Avatar
yeah, i'm leaning towards the rebuild line of thinking now. it should be relatively cheap to rebuild it.
Old Aug 1, 2013 | 08:45 PM
  #27
yeah ive been looking into rebuilding it it should be around $180 and thanks for helping me
Old Aug 1, 2013 | 08:50 PM
  #28
and would the it just be the piston and cylinder or that and rebuilding the crank too
Old Aug 30, 2013 | 12:24 PM
  #29
ming01's Avatar
Default hi
Have you tried starting it with the fuel cap off, coz if the breather is blocked then it will bog... if that works then get a new fuelcap or try and free the blockage ( had that problem with mine when i first bought it )
Old Aug 31, 2013 | 10:47 PM
  #30
armagh's Avatar
I don't know what this means;
"same as before, do you think that the valve might the restricting the gas flow?"
you have 30 posts and as near as I can figure out You have a fuel flow problem TO the carburetor, remember I am having to guess here.
So you asking jasper94 if you need to rebuild something, and again I am guessing the carburetor and him saying he is leaning that way is bad advice as near as I can guess.
Remember you didn't give ANY information about your problem and I looked through your past posts to try to find out what you are talking about so I could try to help you.
And jasper94 when you read this maybe you can shed some light on what his problem is and WHY a rebuild of that part or engine area, that he thinks is going to cost $180., is necessary.
If it is fuel flow TO the carburetor, What is he going to rebuild? the gas line? the needle and seat? the pit ****?
