carburetor issue and needs replacement
Old Jun 7, 2013 | 07:19 PM
acedriver1997's Avatar
Default carburetor issue and needs replacement
i have a 90cc blazer atv and im looking to buy a carb for it but adlyparts will sell one for $140 while similar carbs go for $25 what should i buy for it/fix it. when ever i give it gas it bogs after a few seconds of riding then will stall if you dont let off the throttle
Old Jun 8, 2013 | 10:22 AM
bigge_al's Avatar
sound like you need the carb cleaned and adjusted.
Old Jun 8, 2013 | 03:17 PM
ive cleaned many times and differnent ways and attempted to adjust it but the best settings are where they are now and its having the bogging issue
Old Jun 8, 2013 | 07:28 PM
Jaster94's Avatar
define "cleaned the carb". did you physically pull the jets out and clean them? can you see daylight through them? all orifices? did you pull the needle valve/seat out and clean it? sounds like a fuel delivery issue due to not meeting demand. have you checked the intake boot for vacuum leaks?
Old Jun 8, 2013 | 07:54 PM
i puller out the jets sprayed them with carb cleaner and made sure that i was ablt to see throught them and then sprayed the bowl and the rest of the carb. then other times i dipped it in a gallon can of carb cleaner for 30-60 min which worked for a while but then it went back to not driving. i used a compressor to make sure there was no blockage of the tubes/passage ways and there are no leaks and the needle valve and intake boot is clear the way it runs i checked today is that there isnt enough gas going into the carb bowl. it will idle great but if you give it too much throttle it will drive great till the gas in the bowl runs out and it will stall and only start after a few moments after more gas flows into the bowl
Old Jun 9, 2013 | 07:29 PM
Jaster94's Avatar
ok, your needle valve is sticking open, but it's almost closed. pull it apart again, spray carb cleaner in it, run a QTip in/out of the seat, blow it with air to remove any cotton strands, put it back together. while apart, poke a small gauge wire in the orifices of the jets and down the center to verify there ain't NO small pieces of debris. even a little can stop fuel from getting to the cylinder. once the float/needle valve is reinstalled, use your finger to actuate the float up/down and verify the needle valve is moving, if not, redo it. if it does move freely, install float bowl and fire it up.
Old Jun 10, 2013 | 05:38 PM
thanks next time i have the chance ill do that and see how it works
Old Jun 12, 2013 | 04:38 PM
so idid what you said plus bought a carb for it but it still bogs even with the new carb on it the only differnce i saw with the new carb was a faster and easier start
Old Jun 12, 2013 | 04:53 PM
so think it would just be an adjustment and if so what needs to be adjusted and is there a possibility that it could be the timing and if so how? thanks
Old Jun 12, 2013 | 09:30 PM
Jaster94's Avatar
does that intake boot have an O-Ring on the flange? if so, is it facing the right way? I mean, a vacuum leak could cause bogging due to not enough fuel and too much air. please check that.
