What type of fuse
Old Jun 29, 2013 | 10:02 AM
BSLICER25's Avatar
Default What type of fuse
Does it matter what type of fuse i use for my quad as in AGC or GMA?
Old Jul 2, 2013 | 03:17 AM
armagh's Avatar
In this case no it does not matter just a fuse with the correct amp value.
However Lynn Edwards may have more to offer on this issue and I would most certainly take his advice over mine anytime, Every time.
Old Jul 2, 2013 | 06:50 AM
Jaster94's Avatar
you're talking about the inline glass fuse, right? not the twin blade, right? i'm not that technical on fuses to be honest with you. but install one that is no more than a 7 amp fuse. do not go bigger. that is usually the standard on inline fuses for quads.
Old Jul 5, 2013 | 08:44 PM
BSLICER25's Avatar
put in a 7amp fuse and it blew i should be using 10 amps
Old Jul 6, 2013 | 06:35 PM
Jaster94's Avatar
well, if your 7 amp immediately blows, i think you got a grounding issue and the voltage is spiking. that fuse is designed to be the weak electrical link. it's been my experience and a lot of threads that show a blowing fuse is usually caused by voltage issues...usually a grounding issue.
Johnny Mac
60
Dec 14, 2019 06:13 PM
Sassinm1
Sep 30, 2015 04:23 AM
Lucas Bohanan
Sep 29, 2015 01:16 AM
Nosniborpapa
Sep 19, 2015 07:07 PM
