blowing fuses
Old Aug 6, 2013 | 01:33 PM
billw's Avatar
Default blowing fuses
new guy here.
im trying to fix my little girls atv its a peace 110cc.it keeps blowing the fuse,anyone else have this problem?
Old Aug 7, 2013 | 06:07 AM
Jaster94's Avatar
you've got a "hot" wire that's grounding out and blowing the fuse. you need to start testing the wiring in that circuit, inspect the wiring harness for deficiencies and repair/replace that portion. look for kinked wires, broken wires, or wiring that has rubbed a hole in the jacket insulation and is grounding out.
Old Aug 7, 2013 | 06:08 AM
Jaster94's Avatar
what size fuse? i would say it has to be no more than a 7 amp fuse.
Old Aug 7, 2013 | 07:00 AM
billw's Avatar
Default fuse problem
ok thnx ill start checking wires today.oh btw will the plastic body come off if I remove the Phillips screws?
Old Aug 7, 2013 | 04:22 PM
Jaster94's Avatar
yes sir, that plastic body is made to protect the frame and chassis and shield the rider from flying debris kicked up by the tires. just remember which fastener goes where as you remove the plastics/fenders. that's one of the many things a dealer/mechanic will remove so as to get a better inspection and achieve easier access to the frame, wiring harness/loom, and other equipment on the quad.
xreynolds95
Technical and How-To Articles
Nov 19, 2024 03:52 AM
franklyme
Oct 21, 2016 07:18 PM
Lucas Bohanan
Sep 29, 2015 01:16 AM
Nosniborpapa
Sep 19, 2015 07:07 PM
