wiring diagram
Old Aug 7, 2013 | 04:26 PM
BobbyZitro's Avatar
Default wiring diagram
I have 2 Chinese 4 wheelers that I have no idea what name brand they are. They are 110cc utility looking 4 wheelers. I had a number of problems when I bought these on craigslist and after replacing a starter on one of them, I noticed that I cut the wires to the auto clutch. Not sure what you call the plug, I believe that it has 4 or five wires going to the plug on the gear box behind the stater. i stripped the wires and wire nutted them and it all is working well, but the display is gone. Does anyone have a parts/wiring diagram for these Chinese 110 atv's? i believe it is a 2007.
any help would be appreciated... good news is that they both are running well now after several hours of work and my 4 and 7 year olds are having a blast.
Old Aug 7, 2013 | 04:36 PM
Jaster94's Avatar
some quads have a metal ID tag on the front near the grab handle, some are placed under the seat area, others have a metallic sticker on the vertical downtube of the handlebars below the fuel tank. look for the 17 digit alphanumeric VIN also, usually on the left side horizontal frame tube below the engine. post some pics under your profile's album and we may be able to tell what it is by looking at them.
Old Oct 9, 2013 | 12:22 AM
Ace1996's Avatar
Buyatvsonline - Chinese Atv Parts Scooter Parts 110cc Parts 150cc Parts 70cc Parts 90cc Parts 50cc I use this website to get parts as well as wiring diagrams to most of the chinese vehicles. Once you have identified the quads you should be able to locate the correct diagram on the site. You can sometimes just go by the cdi pin diagrams. Just locate your cdi and count the number of pins it has and find that diagram.
Old Oct 9, 2013 | 09:11 AM
Zrock's Avatar
Super Quad Patrol
get rid of those wire nuts and get some proper automotive crimp connectors or solder them and shrink wrap. wire nit connectors will fall off with the vibrations. Im thinking you cut the wires to the stator. they sometimes go down in between the gear box behind the startor and then gt routed to the stator..
tombrown14
Aug 26, 2015 07:30 AM
Atvnewb88
Aug 19, 2015 02:22 AM
Atvnewb88
Aug 13, 2015 06:48 AM
Tadej Dylan Vuzem
Jul 27, 2015 07:26 AM
tweeder
Jul 5, 2015 01:57 PM
