Bashan Blue and White Smoke When hot
Old Aug 18, 2013 | 02:20 AM
leerx7rsuk's Avatar
Default Bashan Blue and White Smoke When hot
Hi All yes i have a Bashan 200S-7 (2008) I know another chinee chocolate quad LOL but please help????
I drive it every day to work and last week on the way back i noticed it overheated and lost all coolant (Turned ot to be the Radiator). Bought a new one when i come to fit it the fan fell apart so bought a new one. Back running but when it was hot i was getting puffs of white smoke and the odd blue smoke when i stop and drive off again and splutters while puffing it out and if you stop it stalls.
As it was white smoke i replaced the head gasket yesterday. Ran very well and quiet (adjusted the tappets while i was at it) took it out and after it got hot it spluttered again and puffed white smoke out then puffed blue out..then was ok but stalls when idling
Can anybody help as i think i may have to book it in to a shop as dont wanna replace parts for nothing
Could i over filled the oil????
Lee
Old Aug 18, 2013 | 10:09 AM
leerx7rsuk's Avatar
Any help on this ..pplleeaassee..pretty desperate on getting it fixed
Old Aug 18, 2013 | 10:49 AM
Jaster94's Avatar
we're thinking. or at least i'm pondering about it.
Old Aug 19, 2013 | 01:37 AM
leerx7rsuk's Avatar
Tut tut c'mon guys pretty new to quads. Anyone shed a light. Think it's my piston rings completely blue smoke and runs like poop only when the quad gets warmed up. Think now the head gasket is fixed and getting more compression its giving my worn rings more stick.. Wot u all think
Old Aug 19, 2013 | 01:26 PM
Jaster94's Avatar
although i'm not real familiar with your quad, i presume you've checked the thermostat to make sure it ain't sticking closed? i hope you didn't toast the rings.
Old Aug 19, 2013 | 01:42 PM
leerx7rsuk's Avatar
Well I've not checked the thermostat as such but when it gets warm the pipe back to the rad gets warm so I presume it's working. I'm presuming it's the rings due to the blue smoke
Lee
Old Aug 19, 2013 | 06:52 PM
Jaster94's Avatar
although i've never experienced this issue, i presume you're right.
Old Aug 19, 2013 | 09:00 PM
brumbear's Avatar
check compression and you will know for sure
Old Aug 20, 2013 | 02:37 AM
leerx7rsuk's Avatar
i would but dont have one to hand..its getting stripped tonight easy job 1 hr max
Old Aug 20, 2013 | 12:33 PM
leerx7rsuk's Avatar
Right!!!! just took carb off and its caked in oil inside and took spark plug out and its oiled up the same and stinks of fuel....i filled the oil up buts in on the max line not over???...do we still think its the rings at fault???
Please reply asap as wanna get it fixed asap
