Not charging - stator OK I think
Old Sep 10, 2013 | 01:21 AM
iPuffy's Avatar
Default Not charging - stator OK I think
Hey Guys,
Great forum ! While this is my first post, you guys have helped me out a few times.
Normally if I search hard enough, the answers are there but this time Im stuck.
My problem is the battery will not hold charge. I don't THINK it is the stator as the ATV runs fine without a battery.
I tested the AC current from the stator and getting 18v to 20v on both the yellow and white lines.
Tested the DC voltage output from the rectifier and only gives me 6.8v .
I though awesome, easy fix. Purchased 2 x 4 pin rectifiers, tested both and still only getting 6.8v
Any ideas what could cause the output voltage to be so low?
ATV is a GY6 125cc
Thanks !
Old Sep 12, 2013 | 08:33 PM
armagh's Avatar
You should have a regulator, a voltage regulator. I don't know what kind of bike you have, but maybe it is the regulator. If the battery is not holding a charge, ( when you put it on a charger), then it is your battery that is bad.
Old Sep 15, 2013 | 07:11 AM
iPuffy's Avatar
Sorry, isn't the rectifier / regulator the same thing?
Bike is a Hunter Lei aka GY6
Old Sep 17, 2013 | 09:50 PM
jdtractor2020's Avatar
yes a rectifier regulator is the same thing lol, im having troubles with mine now, i have read in a few forums if they go bad they will not keep the battery charge, i believe mine is bad, but still not sure as its blowing up my cdi boxes lol Its either a sivler in color box with fins on it, or a black one with fins on it with wires coming out of it alot of the times they put them near the battery.
ultangler
Nov 30, 2024 01:35 AM
ReconBayou
Oct 31, 2022 05:37 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
kbazzy
Sep 26, 2015 11:26 AM
zPuls3
1) Engine problems..
Sep 12, 2015 08:54 AM
