250 hi bird no spark
Old Nov 24, 2013 | 07:21 PM
ford truckin it's Avatar
Default 250 hi bird no spark
I have a 250 hi bird my brother-in-law got it not running I put a carb on it and it ran fine the gear lights didn't work one day I was messing with the wires at the trans and found the piece broken to show what gear put it back together and I hasn't started since I'm a ford tech and I can seem to make any sense of this tried a new coil and cdi box not sure if I got the right one I ended up with three one was the same size it didn't work I didn't check it before but I replaced the stator I found two wires chaffed toutching metal one of the colors was different on the new one not sure if it's right but I had 48 volts ac going into the cdi box but still no spark help please
Old Nov 25, 2013 | 12:59 PM
Jaster94's Avatar
you've checked the red slider kill switch on the left handlebar, correct? so it cranks but puts up no spark? right?
Old Nov 25, 2013 | 05:08 PM
Yea I just pulled the pin out of the cdi connector
Old Nov 25, 2013 | 06:57 PM
I just looked at it the one of the green wires at the cdi just broke and was corroded I can light a test light but it's very dim on the two yellow wires the ac circuits coming from the stator
fordfaithful21
Dec 7, 2015 05:52 PM
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
MrTrashMan2U
Sep 9, 2015 11:11 AM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
