Need Help: Starter button doesn't work, keyfob does
Old Nov 25, 2013 | 03:45 PM
mauserfan's Avatar
Default Need Help: Starter button doesn't work, keyfob does
Hello, new to the forum.
My brother in law bought a TaoTao 110F for my niece who is learning to ride. She used it several times over a period of months. One day it died and we could not get it to start. No starter movement at all. Tried the normal stuff like the rear kill switch, battery, etc.
So I figured one of the electrical components got shorted out. I replaced the CDI, the ignition coil and spark plug wire, the Starter Relay Solenoid Switch... nothing. However, today I noticed that I could start it with the keyfob but not the handlebar switch.
I did find the controller box in the rear has one black wire that is hanging loose. It appeared to have some shrink wrap over the end so i think it was connected somewhere and came off. Its the last black wired on the end. Could that affect the starter switch?
Thank you for any help you can give. I hope to have her riding it this Thanksgiving weekend.
a few pics are on Flickr here: Misc motorcycles - a set on Flickr
Old Nov 26, 2013 | 09:33 AM
Zrock's Avatar
Super Quad Patrol
that black wire is the antenna for the remote. sounds like the handle bar control is bad.
Old Nov 26, 2013 | 11:29 AM
mauserfan's Avatar
Thanks Zrock. That helps. I won't waste time trying to hunt down where that goes.
Do you know which wire color coming out of the handle bar starter switch I can use to try to test?
Old Nov 26, 2013 | 12:05 PM
Zrock's Avatar
Super Quad Patrol
not to sure what color your going to be looking for. Judging that it will start with the fob im thinking it somehow runs back to the control box for the fob so the fob will over ride all other controls. Have you tried unplugging that box and see if it will work? You 110 looks identical to my Gio 110.
Old Dec 1, 2013 | 06:29 PM
whygostockcom's Avatar
Banned
With the key on, when you apply the brakes is the brake like coming on? If not, you brake switch is bad which is also the safety to let it start.
Old Dec 21, 2013 | 10:22 PM
Nippaero's Avatar
Hello,
Did you find out what it was? Our 110 is doing the same thing. Only the remote works.
Old Dec 22, 2013 | 08:24 AM
mauserfan's Avatar
No I didn't but I suspect the controller box in the rear. For now we are just using the key fob.
Old Dec 22, 2013 | 08:30 AM
Nippaero's Avatar
Thanks. I was working on ours last night and found that if I hold the brake in it will start using the starter button on the handlebar. I am thinking about disconnecting the remote alarm system now.
ripperray
Oct 10, 2023 02:42 AM
txkevin
Sep 21, 2015 02:02 PM
BEEFKING69
Jun 17, 2015 12:38 AM
jag6510
Jun 15, 2015 05:59 PM
bbehrendt
May 28, 2015 09:25 AM
