Kazuma Meerkat 50cc idle
Old Mar 9, 2014 | 04:56 PM
4thgenceli's Avatar
Default Kazuma Meerkat 50cc idle
Trying to figure out the idle on this thing. I have two screws (one center, the other off center left). Just recently got this thing running after a no-start problem.
I tore apart the carb, removed the float bowl, burned out both jets and verified they were clean. Now it starts as long as I fiddle with the throttle to keep it running. Let off the throttle and it instantly dies.
I think the one off center left is the air/fuel ratio and should be 2 full turns out from full close. Where should the other one be set to to idle? Does it follow righty-tighty-chokes lefty-loosy-flooded method?
Old Mar 10, 2014 | 09:00 AM
Zrock's Avatar
Super Quad Patrol
the one towards the back or your carb (air inlet site) with be your idle/mixture screw. the other will be your fuel screw that takes care of the throttle from about 1/2 and up..
Old Mar 10, 2014 | 09:55 AM
4thgenceli's Avatar
Koolio, I wasn't insane.
Once this is idling right I move onto the Yamaha....
Old Mar 13, 2014 | 04:37 PM
4thgenceli's Avatar
Well something is off.
Got it to get warmed up. Closed the choke, blip the gas it responds but takes a while to calm down to an idle. However, it won't hold an idle in gear. it just wants to die as soon as you hit the gas in gear.
franklyme
Oct 21, 2016 07:18 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
strokesb16b
2) Chassis problems..
Sep 15, 2015 09:19 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Minimod
Sep 10, 2015 08:03 AM
