Need more torque
Old Mar 13, 2014 | 03:38 PM
NRXTM's Avatar
Default Need more torque
I have a little 110cc sunl atv with 14 tooth sprocket in the front and 32 tooth in the back , and I would like to change the front to 13. Would only one tooth off the front make much of a difference? and also would this one fit? thanks
http://www.ebay.com/itm/13-Teeth-Engine-sprocket-gear-sprokit-sproket-drive-13-Tooth-420-110cc-125c-ATV-/291000979293?pt=Motors_ATV_Parts_Accessories&hash=item43c1028f5d&vxp=mtr
Old Mar 14, 2014 | 11:42 AM
LT80's Avatar
LT80 Expert
A tooth down will give alot more torque.
I can't comment on that sprocket.
FYI: 1 tooth on the front equalls 3 teeth on the back.
Old Mar 14, 2014 | 11:50 AM
NRXTM's Avatar
thanks for your input, I guess ill just buy it and hope it fits
Old Mar 14, 2014 | 12:18 PM
TLC's Avatar
TLC
One tooth does make a difference. I drop only one tooth on a dirt bike I had and the bike was much more fun on the trails. Lost some speed but did not care on the bush trails.
Old Mar 15, 2014 | 03:51 PM
brumbear's Avatar
Just make sure your shaft on the output is the same and it is for the correct chain size you should have a 420 chain with a 14mm output shaft IIRC but check em don't guess.
Old Mar 16, 2014 | 09:28 PM
NRXTM's Avatar
Thank you for the help
Old Mar 17, 2014 | 03:55 AM
Quad_Ryder's Avatar
Smile
Yes, one tooth on the front will make a small difference, however if you are not pushing the bike too hard it may be better to go up three teeth.
Old Mar 17, 2014 | 11:46 AM
TLC's Avatar
TLC
If your going to up teeth, thats on the rear sprocket for more torque.
dannytas
Sep 26, 2017 06:31 PM
1ArmBandit
55
Oct 14, 2015 09:03 PM
01ssls1
Sep 22, 2015 06:50 AM
raman8tor
Sep 20, 2015 07:35 AM
Steeldon
Sep 9, 2015 09:38 AM
