Getting gas, getting spark, no start?
Old Apr 1, 2014 | 01:38 PM
mattgrahn's Avatar
Default Getting gas, getting spark, no start?
I have a Sunl 150st and it sparks and shoots gas out the exhaust but wont start... kinda stuck on this one.
-Matt
Old Apr 1, 2014 | 06:48 PM
brumbear's Avatar
Shoots gas out thats not good. Pull your dipstick make sure your oil is not saturated with fuel it sounds like you have a float stuck or a broken or stuck part in your carb.
CHANGE YOUR OIL if it reeks of fuel.
Old Apr 4, 2014 | 02:06 PM
mattgrahn's Avatar
brumbear was right... it was filled with fuel. thanks for that. also stopped gas blowing out exhaust when i changed the oil. but now it runs but bogs when i press the throttle.
Old Apr 4, 2014 | 04:46 PM
Fuel got in the oil because of usually a leaking carb needle and seat in most cases. I'd rebuild the carb or at least replace the needle and seat and check the float height.If not,you may end up with more gas contaminated oil.Probably bogging because of carb allowing too much fuel.
Old Apr 13, 2014 | 05:26 PM
frizman's Avatar
I agree with old polaris tech. Your carb is running way to rich I would take the carb all the way apart be very careful they probly dont make a rebuild kit for it, and clean it real good. Dont spray carb cleaner on the gaskets, I have done this with my last carb and they looked like they melted, had to buy a new carb since they dont make a rebuild kit for mine.
Old Apr 13, 2014 | 10:22 PM
Carb kit listed might fit as it seems to fit everything else and lists your brand. Plus looks like carbs aren't that much more if you can find yours listed.http://www.ebay.com/itm/CARBURETOR-CARB-REPAIR-KIT-GY6-150CC-LANCE-ZNEN-JONWAY-NST-KYMCO-LIFAN-SUNL-BAJA-/200922530550?pt=Motors_ATV_Parts_Accessories&hash=item2ec7ea82f6&vxp=mtr
2x_lung
1) Engine problems..
48
May 24, 2023 05:22 AM
Thanos
Jul 12, 2015 08:40 PM
02Chevrolet
Jun 23, 2015 12:12 AM
sae156
Jun 3, 2015 01:45 PM
1000gade
May 27, 2015 12:37 PM
