Coolster 110 atv crank problems
Old Apr 11, 2014 | 01:03 AM
Pmerkich's Avatar
Default Coolster 110 atv crank problems
My coolster 110 struggles to crank it will crank fine but after several times it stops and the relay just has a clicking sound I have to turn the flywheel with a ratchet then it will crank again any ideas?
Old Apr 11, 2014 | 02:31 AM
Flat battery, bad connections to earth, solenoid or starter, or partial engine seizure. First recharge the battery and check those connections.
Old Apr 11, 2014 | 10:50 AM
Pmerkich's Avatar
I checked connections I installed new battery new selinoid and new starter still same
Old Apr 11, 2014 | 10:51 AM
Pmerkich's Avatar
Old Apr 13, 2014 | 02:44 AM
So we are left with partial seizure. Remove the spark plug and turn the engine over by hand, it should move freely with no sticking. The other possibilities are the new battery is not charged, or you have bought a dud starter or battery. One other point, these small machines won't turn over for long before flattening the battery so there must be a reason why it does not start fairly quickly.
Old Apr 13, 2014 | 08:26 AM
Pmerkich's Avatar
Turns really easily when battery off I put it back on and turned flywheel by hand seems like it has a lot of compression on certain spots
Pmerkich's Avatar
Sorry with spark plug off
Firefighter400
Oct 8, 2022 06:38 PM
greg74
Sep 10, 2019 03:03 PM
clsharky
Jul 13, 2015 02:07 PM
Countrygirl1976
Jul 13, 2015 10:08 AM
