VM22 CArb Swap Help on 110CC
Old Apr 26, 2014 | 07:39 PM
Kbr0125's Avatar
Default VM22 CArb Swap Help on 110CC
Good Afternoon,
I swapped out a the stock carb on a China 110 ATV for a VM22. i am trying to get the idle to work, i have the idle screw almost all the way out but my engine still goes crazy when you start it. Its like its on full throttle. the airflow control thing is all the way down on the inside of the carb. I don't know how the tiny opening it has could have enough air to make engine rev like crazy.
Thank You
Carb VM22 has a 15 Pilot and a 95 Main. Its Stock. I havent really tried to adjust the fuel mix screw all that much, i tried all the way in and almost all the way out and it didn't seem to change anything.
Old Apr 27, 2014 | 10:37 AM
Zrock's Avatar
Super Quad Patrol
have you checked to see if the slide is 180 degrees out or backwards? its easy to do i have done it a few times
bzdok1234
30
Feb 23, 2016 01:55 PM
Waddell4436
1) Engine problems..
Jul 20, 2015 09:46 AM
Waddell4436
Technical and How-To Articles
Jul 19, 2015 04:22 PM
tweeder
Jul 5, 2015 01:57 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
