Baja 90 - spark issue
Old May 28, 2014 | 08:36 AM
konnan1's Avatar
Default Baja 90 - spark issue
So I bought a Baja 90, that the guy had dropped a 110cc Gio(I think) engine in. Worked great for a couple days and then no spark, or if I was lucky a very intermittent spark. Replaced CDI and Ignition coil....to no avail.
Thing is really starting to frustrate me - Any ideas of where I should start next? It turns over great, just no spark(or sometimes a very intermittent one..
Any help would be VERY much appreciated
Old May 28, 2014 | 10:12 AM
Jaster94's Avatar
check the quick connects, you may have a blade inside that has backed out not making good contact. OR, check to see your ground wires haven't rubbed a hole in the jacket and is intermittently grounding out. have you converted to a new NGK spark plug?
Old May 28, 2014 | 10:14 AM
konnan1's Avatar
quick connects on the cdi? or just in general on the atv? Yes I bought a couple new NGK plugs
Old May 28, 2014 | 10:15 AM
Jaster94's Avatar
within the ignition circuit via the kill switches/key switch/etc....
Old May 28, 2014 | 11:11 AM
konnan1's Avatar
Will check that, would it help to disconnect, and some dielectric grease and reconnect as well?
Old May 28, 2014 | 12:00 PM
Jaster94's Avatar
yes, that will help waterproof items.
TheHood
Jul 26, 2015 09:51 AM
Captjay
Jul 23, 2015 12:33 PM
Bob Maurice
1) Engine problems..
Jul 14, 2015 09:05 AM
Unzzy66
Jul 11, 2015 10:01 PM
sublime250
Jul 11, 2015 11:52 AM
