baja150cc gy6 no spark
Old Jul 10, 2014 | 01:54 PM
bubba143826's Avatar
Default baja150cc gy6 no spark
no spark, what can I check, took off and cleaned what I believe is the magneto which had a lot of dust in the metal cover pls help.
Old Jul 10, 2014 | 02:59 PM
Jaster94's Avatar
please check the quick connects in/around your wiring harness/loom. sometimes the blades inside push back and do not make good contact. did you try another NGK spark plug? was it running prior to cleaning your stator area?
Old Jul 10, 2014 | 04:47 PM
Default yes......
Yes it was running before but it's probably been sitting about a year never had spark problems only carb problems so I cleaned the carb before I did anything
Old Jul 10, 2014 | 04:58 PM
Default question
The way I checked was took the spark plug out and put it by the motor and turned it over ....no spark is this ok/correct way to check for spark
Old Jul 11, 2014 | 06:40 AM
Jaster94's Avatar
yeah, just hold the rubber part and crank. you should be able to ground plug up against the jug/cylinder fin area. i presume the magnet pick up in the stator area didn't have any surface rust on it, did it? the red slider kill switch is ok? did you check the wire connections coming off the back of the keyed ignition? sometimes they work themselves loose and will kill spark.
Old Jul 11, 2014 | 06:41 AM
Jaster94's Avatar
hopefully mice didn't eat your wiring and you have a rogue ground.
Old Jul 11, 2014 | 11:48 AM
No rust on the stator just dust and just so you know there's no battery either but it ran before without it. I changed many components on the quad before to get it running before
Old Jul 11, 2014 | 01:05 PM
Jaster94's Avatar
yikes, running without a battery is not good. the circuit was not complete. even if you have an old battery, that's better than nothing. hopefully the regulator didn't burn up.
Old Jul 11, 2014 | 01:12 PM
Default regulator/battery
What's the regulator look like and how can I test if it's not working. What type/amp battery is needed for this unit. Thanks so much for your help.
Old Jul 11, 2014 | 01:24 PM
Sorry I know what the regulator looks like and I actually have a picture of it in my profile /garage if that helps
fordfaithful21
Dec 7, 2015 05:52 PM
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
MrTrashMan2U
Sep 9, 2015 11:11 AM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
