Loncin 110- charging cir???Trying to get it right
Old Aug 23, 2014 | 09:46 PM
SEG's Avatar
SEG
Default Loncin 110- charging cir???Trying to get it right
I was giving the task of putting a Buyang BMX Quad w/ Loncin 110cc back together for my niece. Got it running/driving, but the electric looked like a crack addict chimp with a hammer and hand full butt connectors got there 1st.
Making my own harness, what should be the proper outputs for the stator?
5 wires
Grn-ground
Yellow and white- to regulator
Blu/Wht & Blk/Red to CDI
I thought the black leaving the regulator was charge, but has 6 volts to grnd. Is this correct?
Thanks for any help
Stephen
Old Aug 24, 2014 | 01:11 PM
SEG's Avatar
SEG
Ive read Lynn Edwards post(Battery not charging and others) till my brain hurts.
I think the regulator is bad. The bike runs w/ no battery other than to the starter solenoid. The wire harness was hacked beyond repair. CDI checks out OK- have Start and Kill switches along with Brake inter-lock for starter.
Is there anyway to check the regulator itself??
This is what I have so far.
5 wire stator, which I believe to be a grounded battery charge winding type.
test preformed- using a GreenLee CM950 auto ranging meter
Resistance-
Yel to Wht=.3
Yel to Grnd=.7
Wht to Grnd=.8
Ac Volts
Yel to Wht= 61vac+/- steady fast idle
Wht to Grnd= 20vac @ idle 32vac fast Idle
Yel to Grnd= 18vac@ idle 30vac Fast idle
ReconBayou
Oct 31, 2022 05:37 PM
speedbuff
13
Nov 11, 2020 10:16 AM
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
LemonTea
2) Chassis problems..
Oct 2, 2015 03:50 PM
Jersey General
1) Engine problems..
Sep 13, 2015 01:05 PM
