Baja 250 wire heating up
Old Aug 26, 2014 | 07:32 PM
Jsop's Avatar
Default Baja 250 wire heating up
Any time I turn on my ignition key on the smaller black wire from the battery terminal starts to heat up. I don't know what is causing this. this is happenning when it's not even running. Try to find a short check to ground okay I would appreciate any help thanks
Old Aug 27, 2014 | 07:51 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Check the connection of that wire at both ends.. If you have a ohm/volt meter you could check continuity of that wire.
COFatboy
May 2, 2020 12:06 AM
MikeyBoyesq
Aug 10, 2015 11:11 AM
Jul 30, 2015 09:39 AM
DeFox500
Jul 26, 2015 06:32 PM
