need serious help
Old Aug 27, 2014 | 06:56 AM
jdutra5's Avatar
Exclamation need serious help
hey everyone ive been working on a Chinese quad not sure what model on the bars the foam pad says symco idk but anyways ive basically replaced all the ignition parts except a key switch witch works so things I have replaced are the stator, coil, cdi, and volt reg. The engine spins over but has no spark. fuses are good wires look good except NO SPARK my question is could the alarm on this thing keep it from not starting I don't have the kep fab to try is there a way to bypass the alarm disable am I missing something idk maybe another head can help me out idk people I need some help here please and
Old Aug 27, 2014 | 07:48 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
I would disconnect the wires from the alarm disable box.. normally 2 wires.. cant remember if you need to connect them or keep them separated.
If its got the Chinese plug in it I would replace that with a NGK or what ever you prefer.
Old Aug 27, 2014 | 08:16 AM
jdutra5's Avatar
this alarm box has I think 4-6 wires but ill replace the plug tonight and report back
Old Aug 27, 2014 | 11:31 AM
KTM Patrol
Former Chinese POW!
What size engine does this have?
Old Aug 27, 2014 | 01:49 PM
jdutra5's Avatar
Default engine
I wanna say its a 150 cc or smaller I can find out more deets when I get home
Old Aug 27, 2014 | 01:53 PM
jdutra5's Avatar
4 stroke
Old Aug 27, 2014 | 03:41 PM
KTM Patrol
Former Chinese POW!
Im trying to figure out if you need a NGK C6HSA or a D8ES spark plug..
does the cylinder stick out the front of the engine? or the top? does it have a plastic shroud on it?
Old Aug 27, 2014 | 03:45 PM
jdutra5's Avatar
Its a 107cc and the head is horizontal
Old Aug 27, 2014 | 03:58 PM
KTM Patrol
Former Chinese POW!
Ngk c6hsa
Old Aug 27, 2014 | 03:59 PM
jdutra5's Avatar
Discinnected alarm spins over no spark swapped out with new plug still no spark
