Avanti Intruder 100CC key missing
Old Dec 15, 2014 | 08:18 PM
heli.clay's Avatar
Default Avanti Intruder 100CC key missing
So a neighbor gave me this Avanti intruder and said have fun... if you can get it running, its yours. his kid and mine will play on it and have fun if we can get it going.
heres the catch. NO KEY. It did look like this ignition had been spliced into this system as a replacement, or so it seems. these wires in the picture were all just spliced in.
Size:  32.0 KBName:  IMG_7635.jpg
Is there a way to tie those four wires on the ATV together and just bypass the entire need for the key system? just use the kill switch? or am I better off finding a replacement 4 wire ignition? The colors are all the exact same coming out of the wiring harness that these attached too. The other square plug is for lights I believe and wasn't connected.
Old Dec 15, 2014 | 08:19 PM
heli.clay's Avatar
Old Dec 16, 2014 | 03:33 AM
Find a four wire ignition key set up. Most Chinese bikes follow the old Honda system of two wires connected with ignition on, the other two are connected when you turn ignition off. Lots of these switches on eBay. Normal set up, green = earth, black with white tracer = kill from CDI, red = live from battery, other wire is live to starter and lighting circuits etc.
95wolv
Sep 27, 2024 12:00 PM
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
tysonbully
Sep 28, 2015 02:30 AM
Ridgebackguy86
Sep 19, 2015 12:48 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
