Redcat MPX 150 Problems/Questions
Old Jan 20, 2015 | 11:37 AM
  #21
Steve2011's Avatar
Originally Posted by mywifesquad
There has to be something plugging your master cylinder. Compressed air may free things up.. But you would have to take it apart and re bleed the system..
Bearings should be separate from the hub and be replaceable..
Yeah I took it apart. The only thing I could remove was the handle from the cylinder. Not sure how to get the piston out. It's all one piece now. The other issue I have is I need new seals that go on the bolts that mount the brake liNE to the caliper and master cylinder. Any idea where I can get those? Been a couple motorsports places and they have nothing.
Old Jan 20, 2015 | 02:31 PM
  #22
MPDano's Avatar
Also, on these small chinese master cylinders, they are almost impossible to bleed through pumping the pedal. I pressure bleed mine using a large syringe hooked up to the caliper bleed valve. Open the reservoir and push the fluid using the syringe. You should see old fluid/bubbles come into the reservoir. Once clean fluid and no bubbles in the reservoir, the lines are bled.
If the pedal still goes to the floor, the master cylinder is bad. Non-rebuildable as far as I know. The only good thing about chinese master cylinders is that they are cheap to buy.
Old Jan 20, 2015 | 06:37 PM
  #23
Steve2011's Avatar
This isn't a brake pedal. Its a lever up on the handlebar that the master cylinder is all attached to. Ive attached a picture of the lever and master cylinder. There's another photo below as well. I am in need of the black handle on the shifter selector. Anyone know where I can get one of those or something like it. Grabbing threads with your hand gets old real quick.
Old Jan 20, 2015 | 07:32 PM
  #24
MPDano's Avatar
Same idea. Bleed though the caliper. If no fluid comes up to the brake handle res, it's blocked somewhere. You can remove the hose from the handle to verify where the blockage is.
Old Jan 20, 2015 | 08:09 PM
  #25
Steve2011's Avatar
The line is off and it flows fluid through it with no issues.
Old Jan 20, 2015 | 10:19 PM
  #26
MPDano's Avatar
Ok? Did you reconnect and let it fill the reservoir? Once it's clear of air bubbles, you close the bleed valve while the syringe/hose connected. Then try out your brakes. Report back.
Old Jan 21, 2015 | 07:51 AM
  #27
Steve2011's Avatar
I don't have a syringe. I've been using a oil can that had a lid along with a squirter. I've got a piece of hose that goes from there to the bleeder. I've pumped forever and nothing ever gets into the master cylinder. If I disconnect the brake line from the master cylinder and pour fluid in the master cylinder. You can pump the handle all day and no fluid if any very very very little comes out where the brake line hooks up. When I say very little I mean a drop or two. Does anyone know where I can get the black **** that goes on the shifter selector at. I attache'd a photo a couple of posts before this.
Old Jan 21, 2015 | 10:41 PM
  #28
Steve2011's Avatar
Ok so I stopped and picked up a huge syringe today from a vet clinic. I also took the caliper completely off and cleaned it out. And I took the master cylinder completely apart. Reassemble everything and I tried to push fluid back up from the caliper to the master cylinder up on the handle bar and no fluid got into the resivoir. So we tried to gravity feed and put fluid in the master cylinder and we opened up the bleeder and no fluid will leave the master cylinder. We tried pulling it down through with the syringe also and we got nothing. WTH else do I need to do. I've bled brakes 1000 times on cars and have never had a problem like this. How do tell if the master cylinder is bad or if the caliper is bad etc...
Old Jan 22, 2015 | 06:46 AM
  #29
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Since no fluid is going thru the master cylinder, Id say its bad.. Have you tried blowing compressed air in/thru the master cylinder? Its definitely plugged.
Old Jan 22, 2015 | 08:40 AM
  #30
Steve2011's Avatar
Yes it feels like air comes out. But like said I can disconnect the brake line from the master and no fluid will come out of master. If I pour fluid in the resivoir and have the line disconnected, fluid should come out of the resivoir where the line hooks up should it not???
